Exhaust flange
  • Exhaust flange
    Has anyone made a Downpipe coming from stock 3400 Manifolds? If so - what flange did you use to mate with the manifold?
    I had this cut by a friend and it used the stock 3400 gasket, or a simple 2.5 flange gasket slightly modified to fit the bolt width.
    I made this with it.
    Used only one bend for my application and it came out perfect.
      That looks familiar...
      91 SS . 3400/5spd - S&S, TCE, EP, FFP, SPEC, DSS, K&N . GEARHEAD dezign
        That looks good. I am actually in need of someone to weld it up as well. This will actually be going into an Impala (W-Body) and I know the angles are much different than the N-Body. I will post up some pics of my Manifold and see what your opinion is.
          When I made my downpipe for my car, I just used the stock flange that was on the stock downpipe, and welded 2.5" pipeto that flange. Works perfect.
          3400/Getrag 284 5spd
          350/NV3500 5spd
          2014 Chevrolet Malibu LS
            Slightly separate topic - does anyone know if the 3900 Exhaust manifold will bolt up to a 3400 head? Based on the Part number searches, the 3500 and 3900 Exhaust manifolds are the same, at least for the 06+ Impala. If I remember correctly, the 3500's will bolt up, so this would suggest the 3900's would.
              Two completely different 3500s. The ones in the 06+ Impala is the 3500VVT, which is just a smaller 3900. The 3500 manifolds that work on the 3400 is just a larger version of the 3400. So to answer your question, no, they won't work.
              Brad via Tapatalk
                Damn... I'll stick with the ported 3400's then. TY for the info.
                  Anyone know a part number for the Exhaust Manifold Studs? I seem to be having difficulty find reliable information... couldn't think of a more reliable location than here.
                    Like the studs that go into the head? I got mine at Napa, PN 600-2604.
                      Sweet i've always sourced flanges from the yard and cleaned them up but now ill get a brand new one made with the dimensions jon awesome post
                        Thats them! Thank You sir!!
