the idea, is probably a stillborn for a couple of reasons,
1. the lifter and pushrod do not travel in the same plane, therefore, the use of a guideplate will cause the tip of the rocker to experience thrust loading as the valve cycles.
2. the simple flat design shown here, would require the LIM gaskets at a minimum to be modified, if not the LIM as well.
![](http://i473.photobucket.com/albums/rr98/ericjon262/car%20shit/fiero/pushrod%20guideplate2.png)
with something like this, number 2 is solved, and number 1 is minimized. but then the fundamental engineering problem, will it fit?
got the rest of the valvetrain back in and torqued down. re-installed the bits of cooling system that had to be removed to pull the rockers, and re-pressurized the cooling system. this time it performed much better. still not as good as I would prefer though. over the coarse of about 30 minutes, I lost about .75 psi, compared to the 1 psi per minute I was experiencing earlier at the same pressures before all this work. some of the pressure loss could be the compressed air cooling as well, so tomorrow, I'm going to fill the system and pressure test again.
I also finalized the alternator mount. I still need to extend/re-route the wiring to the alternator, and get a slightly shorter belt, hopefully I can find one 1/2" or so shorter, that will probably be perfect. I'm not as worried about belt slippage as I was before, I did some quick math using very conservative numbers, and determined that the crank has more than double the belt contact area as the alternator, which would be the major load on the belt. the only other load is the water pump, is has about the same belt contact as stock, but on the smooth side, so way less contact area than the alternator and crank. it should be fine. in doing the low mount alternator, I also now need to remount the coils, as they won't fit with the front valve cover on the back, so tomorrow, I'm going to mount them to the firewall of the trunk.
