Originally posted by ericjon262
View Post
The Lancia Delta had that back in the 80s...a group b style fiero would be sweet.
got a little bit more done on the hotside today... I'm going to go ahead and order a couple of bellows to add into it. I've been flip flopping on this since day one, and I figure it can't hurt, it'll just make packaging a little harder..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
what size are you doing for the primary tubes? I like your setup, it's very similar to mine except for the independent runners."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
1 3/8" primaries then 2" merge pipe and 2" to the turbo flange.
The primaries are modeled from Jegs 1 3/8" J-Pipe (2R and 2.5R bends). It will barely support 500 HP. Perfect for a fast spooling street machine. The neat thing about that software is I have each piece identified and measured. So it will be easy assembling with all the pieces pre-cut and labeled. Tack weld to fit. If all works well, I wouldn't mind making another set for material cost. Don't find too many 60v6 turbo headers out there.
Your setup will spool nicely as it is very cooperative to retain the pulse plus reduce pre-turbine volume.......what I like about your build is the over all weight of a Fiero is almost half of my GP.
Have you driven one of these motors boosted yet? 8 psi on my heavy GP is freaking awesome, your Fiero is going to turn heads for sure.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
tiny little buggers! I would have gone at least 1.5 inch, mainly because you're going to have a terrible port mismatch problem with such a small primary,"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
1 3/8 equals velocity though... what is the height and width of the D-shaped port on the 3500 head though?
the 16 Ga 1.625" pipe I was using for my headers fit the flanges perfect, I'll see about trying to get some measurements later today.(I know the flanges are bigger then the ports.)"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
no it's going to be an open plenum... just not as open as it is right now! I do plan to make a fer more changes while I'm in this deep though. I'll post up pictures as they come."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
I like the SUV (I forget which) intake manifold with the flange on top of the upper. Would be bad ass in a RWD setup like a Camaro or whatever. I thought it was out of some Buick crossover vehicle, there are pics of it on here someplace. I can't find it.11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
It's the LNJ 3400 intake, I liked the design, but it wouldn't clear the decklid by a mile, and my 75mm TB still wouldn't fit..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
