  • Got to work on the hotside today...
    I started by cutting a U bend in half
    Then I cut a side off
    Then I welded the cutoff back on 180*
    Then I made a window and started welding.
    Rinse and repeat...
    Almost done.
    • Click image for larger version
ID:	377360I built similar pipes for my iron head 3.1. Click image for larger version
      • Originally posted by 23TrackroadsterV6 View Post
        I built similar pipes for my iron head 3.1. [ATTACH=CONFIG]7270[/ATTACH]
        That looks good! looks like yours are stainless though... When I remake the system when I have time and money to do it, I'll do a stainless 3-1 header setup.
        • Just mild steel
          • I want to have mine ceramic coated, depending on the cost.
            • I'm building a car similar to this one and my pipes are also similar, mine will be HPC coated inside and out as well.Click image for larger version
              • Nice work!
                How are the transitions inside, fairly smooth?
                • Originally posted by Superdave View Post
                  Nice work!
                  They're decent, could be better. but they will flow more then enough for what I need.
                  • well, I've started working on modding a 3400 bin file for my 3500, so far, I have:
                    1. deleted EGR
                    2. imported Maf tables for LS1 Maf
                    3. changed the IFR for my 60 PPH injectors
                    4. bumped up hot idle to 800 RPM in Accessories>IAC>IAC desired idle speed. for the cam.
                    I'm not 100% sure I got the EGR delete right, I lowers the Disable thresholds to 0, and raised the enable thresholds to maximum (speed=255, TPS=100.9961) would this delete EGR? I assume I also need to remove the DTC so I won't get an SES light correct?
                    Thanks-
                    Eric
                    • Got a little bit done on the hotside before it got dark outside....
                      not permanent, I'm going to try to find a 2" V-band clamp, because I won't be able to fit a ball and socket in there
                      • Nice work
                        • Don.t forget to put a flew section in there. It will help stave off cracks. Nice job!
                          • still in progress, I plan to put one in, but I'm still trying to find out where! I also still need to find a spot for a WG too...
                            • Originally posted by ericjon262 View Post
                              The closer to the turbine the better. What ever is bled off will result in less velocity beyond the WG, as there is less gas moving in the same cross sectional area.
                              • Originally posted by TGP37 View Post
                                I was almost thinking about mounting it under the turbo, but I would prefer easier access than that...
