I knocked out a bunch of the little stuff on the list, and some of the things that had me a bit frustrated as well.
one of the big (ish) items I was able to accomplish was getting a dipstick fitted to the engine, which actually worked out to be much easier than I expected.
the 3900 dipstick tube fits the earlier engines, but the tube is longer, thankfully, the 3900 dipstick is longer by the same amount, and the 3900 dipstick sticks out of the end of the tube by the same amount as the early dipstick sticks out of the early tube. Therefore, if you install the 3900 dipstick and tube in a earlier engine, it should fit and read exactly as the early dipstick and tube.
As an added bonus, the arrangement of the 3900 tube puts the tube further away from the head, so it will probably clear most header flanges. it touches my 1/2" flanges, but I suspect it would clear 3/8" it's also in a position that clears my coils! all around, epic win!
In other news, I marked TDC on the balancer and timing cover, once I have the engine back in the car, I'll turn it over and shoot it with a timing light to determine the 24x wheel sensor offset so that anyone else doing a similar swap with a MS3 based ecu can use the internal wheel easier.
I also got the plenum port matched to the lower, painted the alternator and tensioner brackets, and tightened the engine mount bolts up. hopefully tomorrow when I get off work my level sender and fuel pump will be here and I can install them, if that goes smoothly, I might start on the charge pipe and getting the engine back in the car.
