I made a 3 gauge "a" piller setup for a third gen F-body fit my car. looks surprisingly well for a 1/2 custom part, here are crappy pictures.
I wish I had taken a picture of the pod before modification, I'm still working on installing instrumentation, right now, I have AFR, and boost. I think #3 is going to be EGT.
the ruptured fuel line turned out to be one of my "new" lines I had dropped the tank, thinking it was one of the lines hose clamped to the pickup, and then the tank decided to start leaking. I ended up grabbing a tank from an 87-88 car, and installing AN fittings on the pickup, so there are no more clamped connections, then I made new braided fuel lines, all the way from the tank to the rail and back. the new tank is almost ready to go in for good, hope to have it done in the morning.
FWIW, on my 85, the later model tank required the brackets for the A/c lines to, at a minimum, be bent before the tank would fit. seeing as I don't have A/C lines under there anymore, I cut them off and threw them away.
