plug wires/ injector interference?
  • plug wires/ injector interference?
    if my plug wires run very close to my injectors, will that cause an electrical interference issue?
    I wouldn't think so since an injector signal is just the PCM grounding it, unlike an engine sensor actually transmitting a signal through a wire. Injectors are controlled decivices, not input devices.
    Sent from my SPH-M820-BST using Tapatalk
      Agreed you wont have any issues. If you do then you have shitty plug wires!
