I've been having a few issues with the engine ever since the rebuild that are really nagging me. I'd prefer not to just drive it "as is" in case it leads to a bigger problem latter on, but I really just have no idea what the problem is, so I could use some input.
I've been getting something that definitely looks and feels like oil leaving streaks down the front of my block. It's dripping off my A/C compressor and starter, and generally making a mess of my cross member and everything else. From all appearances, it seems to be slowly leaking from between the block and cylinder head.
I've looked everywhere else and had the upper manifold off and can't see it anywhere else. It's only on that front edge. Very strange since only coolant goes through the gasket. It's not leaking from the sides or from the rear head either. They are MLS gaskets from Gaskets To Go who did a group buy through the old 60v6.com store back in the day before Cometic would make them for us. They have a viton coating and are supposed to be able to be installed dry, and the shop who did my machine work told me the heads where flat and both surfaces smooth enough to use MLS gaskets.
The only possible thing I can think of is maybe they aren't sealed well along the edge of the heads and oil could be getting between the layers at the edge of the gasket up in the lifter galley at the drain holes in the heads and leaking around? I just can't imagine why it wouldn't be sealed so tight that oil couldn't get in there, and why it would only be leaking from the front edge of the front bank. When I installed the heads I torqued them to 82 ft/lbs. Directions for the head studs say they need to be re-torqued after running, but directions for the gaskets say they don't. I took the valve covers off anyway and checked the torque, and re-torqued them to 90 ft/lbs to see if that would help, but it still leaks.
The other problem that's nagging me is occasional white smoke out the exhaust. It only happens at idle in gear or parked, but not all the time. Doesn't matter if the engine is hot or cold. I can be out driving and sitting at a light and look in my mirror and see wisps of smoke rising behind the car, take off and it goes away, get to another light and see nothing. Get home and get out and look and see nothing coming out the exhaust, but a few times I have. It's never consistent when it happens. The coolant and oil levels aren't going down fast enough (if at all) to tell me what I'm burning. Can't decide if it's another problem with that head gasket, or some problem with the piston rings not sealing well sometimes when the engine isn't loaded? It's really got me worried though. I don't want to have to tear the engine apart again to replace the head gaskets, and I can't afford to pull it again if it's a problem with the rings. I did everything the manufacturer recommend though with the rings so I have no idea what could be wrong.
I guess at this point this engine just has me paranoid. I'd really like to not have an oily mess all over my engine and gunking up my compressor and starter motor though, and I'd also like not to be burning coolant or oil and fouling up my sensors and cat. Any suggestions?
