The LZ pullies are the same as LX9s and can be removed with a 3 jaw puller. I have always been able to get them off with a cheap Harbor Freight puller. I do stick a short bolt in the end of the crank to protect the threads.
Some places list it as a Chrysler puller, while others list GM/Chrysler. You should be able to rent it at any local auto parts store that does tool rental.
2000 Grand Am GT 2011 Chevy Impala
Got it off. Wan't to hard actually. The toughest part was not ruining the threads on the crank since for some reason all but harbor freight pullers do not have a taper on them only a center point. So you have to be careful not to dig into the crank.
I've come across a lot of people messing up their threads when removing the damper and I really don't understand it. If you have any change laying around you can easily avoid trouble. The last time I removed a damper and couldn't find the proper button for it I just stacked a couple quarters over the bolt hole. Much easier than trying to fuss with rethreading it. Hopefully people search and read this beforehand and save some time and effort.
