1980 MGB restored, 3.4l converted to 390 cfm Holley carb, vacuum advanced dizzy built for this setup, ect.
Really excited about this. I'm totally a newb to carbs and the 3.4l 60v6 so I really need your help with these few questions.
I know how to search but didn't find what I was looking for.
I really appreciate anyones help here, I have pics in the intro forum.
- timing procedure with the carb and vacuum advance?
-I have the new GM break in oil additive. 1 bottle is all I though I needed, I'm guessing to just use that on the first start up only and then reg oil after?
-do I need to run the electric choke carb through a fuse?
-using a small 7 row oil cooler, about how much oil should I use and what type seems to be the most common?
-any one have the GM break in procedure on a PDF or something? I can't find mine.
