Hey everyone! I am new to this web site, so i figured I'd start with a good post for my first one!
I am currently going to be swapping out the engine in my 1995 Base camaro, 3.4L V6. The engine that is now in it has a left head gasket leak, is from a 1994 camaro that the previous owner swapped out, and has 160 000 km's on it. It's running a bit hot, and I found rust in the rad fluid when I flushed it in june, and the rad fan stopped spinning after the flush (sensor issue, replaced relay, tested motor, continuity in wires etc..) so it's definitely time to swap out this old engine...
I was just wondering WHAT models would be compatable for this vehicle. It's an ironhead engine currently, rear wheel drive. I know the engine has to be non vvt (the ecu can't handle vvt) but what models would work? I was told an 04-05 malibu may work.. Grand Am's maybe? Not too sure about various engine mounting points or anything so was hoping for some insight.
Would greatly appreciate the help! Thanks guys
