Unfortunately, they aren't for sale. But, if you have a drill press, some big bits, and somewhere to get a chunk of aluminum, you can build one yourself. See attachment.
hey ive seen your car around. if you want a big throttle body i have a 65mm one from a 3.5l dohc motor. wottech has an adapter for that throttlebody on a 3100 or 3400 intake, you might need to port out the plenum. you would have to figure out the cable situation. you can come out to oronoco junk yard and pick upthe throttle body from me for $10. text me 507-696-9227
really?(well then you probably have seen how it looks now, halfway in the progress of painting it) Do you live around the Roch area? I havent seen your Fiero around do you drive something else? Oh i dont have a phone right now ether cause I spent too much on the engine and bill ect. also will it fit on the Gen II 3100 or just the Gen III? I have the Gen II intake.
Later,
John www.a-body.net
Garage:
'88 Buick Century "GS"--Gen II 2.8 MPFI, TH125HC; Being swapped to LG5 3.1
'86 Camaro IROC-Z--305 TPI
i would think it could fit your motor. i dont know about the adapter. i just sold a turbo from one of those motors about a month ago. a motor came in the yard locked up and i took the turbo and flanges off. but i know that it fits on the small port 3100. just a little modifying and everything works. i can find out for sure if you need it. i do live between chatfield and theilman (down by wabasha). i drive a sohc neon for a daily driver. the fiero is in the middle of a motor build and swap
