Most of these posts are verbatim copied from the a-body forum where I originally posted. This is my second 60°V6 turbo project; and 6th overall turbo system to build and install.
Well, the time has come to start this project! Hopefully I will be able to get it done before life gets in the way and I have to leave it for a few months again!
My goal here is to use ONLY the parts from the donor car (TGP), other than the pipework and odds and ends.
The TGP intercooler is oddly shaped and undoubtedly custom made for the TGP front end. It was not easy to fit into the Ciera and I have yet to get the air pipework completely sorted out. But I have the cooler mounted, and also the pusher-fan that was optional on all the A-cars.
First, I took off the damaged header panel. I have a new one that will replace it. Just have to put some gray paint on it first.
.JPG)
These two items will need to go in front of the condenser behind the bumper. The intercooler is an odd shaped thing with the spouts pointed in crazy directions!
.JPG)
Made a bracket (used pieces cut out of an old tool box) that supports the end of the cooler, and the lower mounting foot of the pusher-fan. Welded it onto the stiffener piece that goes over the condenser.
.JPG)
On the other end, I made a bracket that catches a bumper mount bolt and bolts to the other end of the cooler. You can see the severe angle of the hose spout on the cooler. I will have to get a rubber hose with a 90° end on it, laid inside the bumper channel to route air to that port.
.JPG)
And here's how it looks all together!
.JPG)
.JPG)
Got an update today!
Started by removing the crossover pipe and surveying the room available.
Next, I took off the stock rear manifold and compared it to the McLaren Turbo rear manifold. See the difference?
Turbo manifold fits nicely, with new gasket of course!
Next, the turbo crossover goes on. Fits like it was made for this engine! But it needs some support. The factory McLaren TGP had a different transmission. I will have to build a bracket.
To the uninitiated, this may look like an old hydraulic pump mount. But to me, I see a turbo crossover support!
See, I found there WAS indeed a turbo crossover support hiding inside that old pump mount!
That crossover will NOT vibrate! Could probably lift the entire car by it...
Turbo, downpipe, and some of the cooling lines installed.
Unlike my previous, fully-custom turbo systems, the transmission dipstick tube clears the downpipe with only slight re-bending.
A couple things I learned for those possibly doing an LG5 swap, or turbo system swap. Firstoff, get EVERYTHING you can off the donor car. Fuel lines had to be used from donor. Front part of muffler pipe (between turbo downpipe and catalytic converter) has to come from TGP. There are some other heat sheilds and odd and end hardware that would be a pain to locate or build, but is factory installed on the TGP.
Since the TGP had a 440T4 transmission, and this car has a 125C, the TV cable comes out at a different angle. Somewhere I have a custom made steel one that I had on my other car. I will probably have to use this on the Ciera. There is no way the plastic one will live in this close proximity to the turbo. I did keep the TV cable from the TGP, but I don't think it will work because it is too short.
I'll be working on it over the holiday weekend, but parts availability and family fun will probably slow me down!
Also, since the header panel has to come off to get to the intercoler, I painted the replacement one I got from the JY. Someone had run into something with the original one. The new one was gold, so I painted it the same gray as the car. I simply pressure washed it with degreaser, then wet sanded it with red scotchbrite before painting it. It is not perfect, but for this car it is fine. It beats the cracked-up excuse for a header that WAS on the car! I was nearly a road hazard for chunks of fiberglass falling off!
Sincerely,
David
Sincerely,
David
