power above 5k?
  • #16
    thanks for the tips fellas i think i am going to go for a upper+lower topswap and exhaust and intake im sure its not a huge gain but for under 100 dollars im not expecting too much
    • #17
      Without upping the compression, you'll just blow hot air. Change to a iron head rotating mass and then put a cam and springs to match.
      • #18
        for something more streetable, 3100 pistons would be a good option. 9.5:1 with gen 3 heads and 9.82:1 with gen 2 heads.. Gen 1 pistons with Gen 2 heads is 11.88:1 or 11.14:1 depending on which headgasket you use, with Gen 3 heads it's 11.4:1 or 10.72:1 depending on headgasket.
        • #19
          Im not trying to go to crazy here, just go for a small upgrade but the plan eventually is studded 3500+big dumb cam+20ishpsi, i go back and forth of what i want to do.
          • #20
            in a j-body btw
