Weird problem after a fuel pump change
  • Weird problem after a fuel pump change
    Car is a 3rd gen Sunfire, 3500 swap with a P&P'd top end, Street/Strip cam, etc.. OBD1 piggybacked for the engine. $A1/'7730. 36lb/hr injectors.
    It had the original fuel pump from the 2.2, upon tuning I determined that it just couldn't keep up with the engine. I maxed out the VE tables trying to get WOT to around a 12.5:1, even with a dramatic BPC change it just couldn't supply enough for the engine.
    The owner purchased a 255lph pump kit from Racetronix for the 3rd gen Jbody and installed it. He brought it over last weekend for some datalogging/tuning. To our surprise it now will not rev past 6K. Once you get close to 6K it just falls on it's face like it's hitting a rev limiter (which is set to 7).
    He's called the vendor and is waiting for a response from them but i figured i'd ask here to see if anyone's seen it before.
    I can post the datalogs if anyone wants to see them...
    [url=http://www.v6z24.com/registry/SuperDave]1991 Z24, 3500/5 Spd. 275WHP/259WTQ 13.07@108 MPH[/url]
    [url=http://www.v6z24.com/registry/superdave/5]1989 Camaro RS, ITB-3500/700R4. 263WHP/263WTQ 13.52@99.2 MPH[/url]
    [url=http://www.v6z24.com/registry/superdave/6]1972 Nova 12.73@105.7 MPH[/url]
    is this verified with a pressure gauge dave? maybe a line is pinched, or something overlooked?
    [SIGPIC]
    12.268@117... 11's to come!
    [url]http://www.youtube.com/watch?v=7ibU1k8UZoo[/url]
    [url]http://www.youtube.com/watch?v=GUqJyopd720[/url]
      Haven't checked the pressure yet.
      The day we logged had some weird weather conditions and i noticed that the MAP was only getting up to around 85kpa @ WOT. I wanted to make sure that it wasn't pulling too much vacuum on the FPR so we un-hooked it. It acted a little better but i didn't get a chance to log it after. I'm hoping for Monday afternoon.
        This a E 85 car? The FPR can clog up with debris from fuel corrosion and give funky driveability issues.
        [SIZE="2"][FONT="Arial Black"]Lifting my front wheels, one jack at a time.[/FONT][/SIZE]
          Nope, normal gas.. probably E-10 since we're in Iowa.
            Modify the bucket so it gets more fuel flow. I'm guessing it's sucking the bucket dry.
            [url="http://www.berettaspeed.com"][img]http://kflo.berettaspeed.com/sigs/gt_09_sig.jpg[/img][/url]
            14.60 @ 96.33 for now...
              Not sure if you considered this but, cheap fuel pump filters don't flow as well. I got an ACDelco filter which was much more expensive (for a filter anyways) as they are designed to flow better. Suppose the draw is enough to collapse the pump filter upon itself?
              Just an idea tossed out there.
                I remember reading about bootleg walbro fuel pumps a few years ago.....3x00 modified might be able to chime in on that one
                95 Z26 3400/OBDII/GETRAG
                  I posted about it and informed a few members about it........ IIRC I told Jon about it (3100-modified)
                    we haven't really done a whole lot with this, i think he contacted Racetronix but not sure what they said...
