Do you really need to swap out the check ball spring also or can I just swap out the piston spring and still be ok? Thanks.
LS1 Lifter springs
are 60* lifters different from SBC lifters? I though they were all the same externally?"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
the OD is but the internals are different than flat tappet lifters.
OP, why not swap out the check ball springs?.. it takes 30 sec per lifter once the main plunger is out.
