Ok, so I've been fighting this issue for two years now... best solution I've been using so far is just unplug the knock sensor when I'm not at the strip. But the issue I have is on the highway at 75mph converter locked in 4th if I'm just cruising with nearly no load the KR meter will start to climb and pull timing like crazy, it will pull up to 18* of timing and leave me at 10* advance... Talk about pulling a few pony's out from under you.
As soon as I crack the throttle just a bit more and increase the load the KR begins to go away at the recovery rate... slightly higher speed 80mph it doesn't seem to do it... So I'm assuming this is a sound from SOMETHING or interference due to that specific condition thats causing this KR to apear... With the knock sensor unplugged you can't hear a thing... and I know if it was pinging enough to pull 18* I would be able to hear that. The red beretta I had was pulling 8-9 degrees on the high way once under load and I could HEAR that even when it was pulling the timing.
Slightly higher octane fixed my old car's ping I could hear, but running 93 in this thing doesn't make a difference. I've also dropped that spark advance area down from 34* to something in the 25* range and it still pulls exactly the same amount of timing, which is why I think its an interfering sound of some sort.
Does anyone have any ideas on how to isolate that noise from the knock sensor other than putting that damn wire on a toggle switch?
I've swapped wires and that didn't fix it, I'm going to swap coils today to see if that changes anything, and then I have an ICM I can test as well.
There is only one other thing that I can think it may be... Due to the fact that I have the intake spacers the top of the coil bracket does not bolt to the upper... I'm wondering if thats rattling in some way to make a noise its picking up. I'll have to see if I can bend that bracket enough to make it to the holes and line up so I can bolt it down.
