1995 3.1l Cutlass help
  • 1995 3.1l Cutlass help
    Hey guys,
    I'm new to cars doing research here,
    I have a 3.1l cutlass. Wondering about upgrades...
    Already looking FOR headers.
    Roadmaster intake manifolds n such.
    roadmaster heads.
    62mm throttle body...
    Wondering if the wot-tech chip for the 94 will work on the 95.
    How can i get better bk pressure? Cat delete or resonator?
    Gonna make a custome 3" exhaust in shop...
    Please help me guys n oh 165° or 195° thermostat?
    1995 Ram Air V6
    how much do you know about the 60* and swaps for power? do you know about the hybrid swap? 3" exhaust is too large for any application but a turbo, the thermostat doesnt accomplish anything, theres better gained from a 3400 top swap then the intakes that you would be after. headers might be avalible to fit from other bodys, but someone else will be able to clear that up.
      Got any links for 3400 top swap
      1995 Ram Air V6
        No, 95 is OBD1.5 and it's not documented enough to have a chip burned for
        195° Colder engines run more rich and our engines already run rich from the factory. Couple that with acclerated cylinder wall wear with a cold stat, and as Betterthanyou has mentioned, hotter engines create more power.
            Ty
            1995 Ram Air V6
