Below are the revised numbers on the re-grind of the SSI performance cam, also, if anyone else will be doing this, you will need a different cam sprocket set, the roller lifter cam is retained in both directions, the flat tappet cam is only retained for movement to the rear, movement to the front is done by the slope of the cam lobes which force the cam to the rear of the engine, it is not mechanically restrained for front movement. The cam sprocket is held on with 3 bolts on the flat tappet cam and a single center bolt with the roller cam, Other than that, it is a drop in fit. Larry
