I got all the parts now except the cam, this is a 3.1 bored .020 over with the iron head pistons in it. Goes into a Fiero. Used the coated skirt pistons and will do a little work on the heads/seats for some ZO6 valve springs I picked up. When I get the pistons in the block tomorrow I will measue the clearance I have for the valves and get some roller rockers to get it right when I find a cam. Anyone with a fairly agressive roller cam laying around drop me a note. I'll take a couple of pictures then the crank and pistons are in the block. I will have some fairly high spring pressures, so I think I will need a solid core cam. Larry
Need a roller cam for a high compression 3.1 build
Is this a 3100 block with iron heads or a GenI block?
A GenI block will require serious work to make a roller cam and lifters work right.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Heres a great place to start!!!
Originally posted by trotterlg View PostThis is a 94 gen3 with iron head pistons and aluminum heads. Came stock with roller lifters. Larry
Edit: David Vizard's How to Build Horsepower (SA Design)1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Geoff, you are a little off on the name, but here are some links to the book(s):
David Vizard's How to Build Horsepower: Proven Methods for Increasing Horsepower in Any Engine (S-A Design) [Vizard, David] on Amazon.com. *FREE* shipping on qualifying offers. David Vizard's How to Build Horsepower: Proven Methods for Increasing Horsepower in Any Engine (S-A Design)
Originally posted by bszopi View PostGeoff, you are a little off on the name, but here are some links to the book(s):
http://www.amazon.com/How-Build-Hors...2988191&sr=8-21993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Originally posted by betterthanyou View PostThanks edited. LOL I have the damn book in the bathroom for reading on the shitter so I see the name every day.-60v6's 2nd Jon M.
