Been lurking this site a lot as I am hopefully going to be buying a Miata as a track car some time in the near future, and I want to put a 60 degree V6 into it because they're light and you can squeeze a fair amount of power from one naturally aspirated.
Just been looking around and reading on high compression(but 93 octane safe) builds because I want to essentially build it with the best of the best stuff to achieve perfect quench, a high static C/R, and an acceptable dynamic C/R. Of course good flowing heads and a good sized cam... solid roller if necessary/possible. I'd like to have 275RWHP with a broad torque curve over 2000 rpms... basically something that has good throttle response and can take a beating on a road course.
I know it will either take a completely done over 3500 or a 3400 hybrid... whichever I figure out is easier/cheaper to get the desired compression and quench.
For now I'm basically just dreaming up a combination and absorbing knowledge, read a lot of the stuff by Super Dave and Joseph Upson... lots of good info in their posts.
Also, I found this kick-ass calculator... it's meant for Jeep strokers but you can plug in stuff for anything really:
I guess this is sort of an introduction, but moreso I may post back in here some stupid questions of mine so I don't clutter up anything elsewhere
edit: I'm trying to plug in all stock numbers into that calculator for a baseline... does anybody know what the 3500 LX9's intake duration # in degrees is? And what the dome or valve relief CC is? Thanks!
