Well I dropped the engine off at the machine shop today. This is where I took it. http://www.enginelaboftampa.com/index.html They have a good reputation locally and seem to do good work and have a really nice shop. A little more expensive than some, but I'd rather have someone working on it that knows what they are doing.
They have worked on a few 3.4's before, and said they have found problems with the cam bore not always being straight. They said that might be a problem with mine and might have had something to do with the oil pump drive wearing out and the cam bearings going bad. They are going to tear down the rotating assembly and tell me what they find, and if the cam bore is off I am going to have them align hone it and put in over size cam bearings. Since the entire rotating assembly will be apart I may have them balance everything too. Depends on if I get the money in soon that I am waiting for. They charge about an extra $370 for that, but they said I could rev to 7000rpm and could gain up to 10% HP just from that, and it would have better longevity and possibly less strain on the timing chain and valve train. So I'm thinking about it.
I decided to keep the LS6 valve springs, and I will probably have them machine the spring seats on the heads so I can install them at 1.8" and drop the seat pressure just a touch and gain some available lift for future use. I also ordered the LS lifter springs and a 3500 valve set from Ben, and will have them do a valve job with those once I get them here. I already have a new oil pump drive and timing chain on the way, but I'm thinking about whether I should get the 96-99 timing set or not. Even with the stock cam, I'm not sure if the stiffness of the LS6 springs would still stretch the chain out or not. The one I took off wasn't too bad but only had 12k miles on it. I still have a set of stock length stiffer pushrods from Smith Bros so I'm not worried about pushrod deflection.
