Hey guys. Been a while since I posted any updates on my build in here, so I'll get up to date first.
Fixed a bunch of issues I had with the belt, tensioner, and alternator, and ended up getting more boost. 9.5psi @ 6400rpm with a 2.2" pulley. Also installed a 2bar MAP and got that working so I could log the boost level. I dyno'd the car a couple weeks ago and ended up making 320whp and 300 ft/lbs on the last pull with the exhaust cutout open.
Injectors were hitting 21ms pulse width from 5600rpm up and AFR's went from 11.6 to 12.6 in the last 1000rpm to redline, so I figure the injectors are maxed again. Guess I should have kept the Lucas 42's I had. Anyway IAT's where getting in the 90-100 degree range at full boost and removing timing wasn't helping anymore. Really need an I/C or alky spray to cool it off, but I figured I'd throw a few gallons of race gas in it or drop the redline a bit to control the KR and take it to the track to see what it would do.
First run was a new PR of 13.788 @ 103.73 mph, with wheel spin off the line, and it seemed to be hitting the rev limiter on the shifts. Second run I feathered it off the line and hooked better, and it seemed to shift better. 1/8 time and speed looked on pace to hit a 13.6 maybe, but right after the shift into third something let go. Engine started sputtering and huge cloud of white smoke out the back. Still ran a 13.8 but only at 96 mph. Got to the end of the run off and turned into the return lane and the engine died. Low coolant light was on. Coasted off into the grass and stopped. The PCV valve had been blown out of the valve cover and blew oil/coolant up on the hood, and there was coolant pouring out of my exhaust cutout!
