Full street trim. nothing removed from the car, stereo was still in there even. LOL...
full exhaust (i didnt open the headers up just yet) thought i'd try the new system and see what it can do with the full system on there.
stock ECM programing blah.
60foot: 2.299, 1/8th: 9.533 @ 75.093, 1/4: 14.694 @ 95.572
60foot: 2.160 1/8th: 9.434 @ 76.619, 1/4: 14.580 @ 96.557
60foot: 2.273, 1/8th: 9.481 @ 76.122, 1/4: 14.623 @ 96.266
60foot: 2.308, 1/8th: 9.435 @ 75.275, 1/4: 14.548 @ 96.488
60foot: 2.220, 1/8th: 9.394 @ 76.023, 1/4: 14.517 @ 96.258
60foot: 2.190, 1/8th: 9.396 @ 76.307, 1/4: 14.512 @ 96.465
60foot: 2.182, 1/8th: 9.347@ 76.069, 1/4: 14.486 @ 95.912
60foot: 2.285, 1/8th: 9.372@ 76.120, 1/4: 14.456 @ 95.729
and the best of the day:
60foot: 2.134, 1/8th: 9.289@ 76.150, 1/4: 14.391 @ 96.479
cant wait untill the Holley ECU and new injectors go in, still have to wire up the MSD DIS4 as well. and i'd Love to get some Drag radials or go all out and get some slicks!! :P
the Transmission was fixed from last years dissapointing let down of no 4th gear under load.. turned out to be a bent shifter select notch on the 3/4 rail... so when under load it would slip past and not push on the rail.. ruined the synchro and blocking ring.
transmission was repaired with the following:
new 3rd blocking ring,
4th blocking ring
3/4 Synchro/hub
swapped the 5K mile new 3rd blocking ring for 5th (those 3 use the same rings) due to the 5th gear was starting to catch a few times.
snagged a 3/4 rail from one of my parts transmissions as well to fix the bent shit.
the LSD from Engineered Performance was Upgraded from the "street" setup i had to the full on "race" spec.. Again EP are a great company to deal with. they had my diff back to me in no time at all!
and the trans got a bit of a closer ratio fix as well, aquired another spare parts trans a while back...
1.03:1 4th gear (stock was 4th was 0.94:1)
and swapped out the stock 3.61:1 FDR for the 3.94:1 gearing.
i left 5th alone instead of the upgraded .80:1 i left it stock at .72:1 for better highway mileage with the low FDR gearing. (dont use 5th for racing anyways)
was a fun day.
heaps of area's for improvement on the car. should see a bit better time from me this year yet.
4th blocking ring
3/4 Synchro/hub
was a fun day.
