first off, what do you want? you can achieve any other compression ratios with the speed pro pistons than i already stated, which is 9.5:1 or 9:1 or 12.5:1 or 12:1, (the first sets of numbers are for a 3400, second are for a 3400/3500 hybrid, which has 3500 heads with larger combustion chamber)
you seem to have a lack of understanding of how you get a higher CR, in laimest terms its making the combustion chamber size at TDC (Top Dead Center) smaller or larger. So a piston with a lower pin height is going to have a higher CR, As the whole piston has moved up. figuring out all this information for yourself is kind of a pain in the ass, but its possible.
If you select 3.4 iron head in the CR calc. you will have your values for the piston dome volume, same goes for the 3400.
when i wake up i might figure the whole equation out again
