I've done some reading, here's my situation, let me know what you guys think. I'm rebuilding a '99 3400 for road course enduro racing. Motor runs fine, has 150k on it, needs LIM gasket, going to do head gaskets and port/polish while I'm at it. No plans for a cam, this is already a big enough upgrade from the old MPFI.
I've read about valve float on stock 3400s, especially with high mileage. I will probably set the rev limiter at 6, but would like to be able to string it out and hold it there without float.
From what I've read, LS2/LS6 valve springs are too stiff for a stock cam, but LS1 springs are just a bit stiffer than stock 3400. Also, 3500 springs aren't any different?
So, what I'm looking at is a set of LS1 springs and seats, and 3.1 MPFI seals. Would this work well with the stock 3400 cam to eliminate high-RPM float? Is there an aftermarket spring option, or other drop-in replacement that will fit the stock spring seats, or are LS1 springs the way to go? TIA.
