I got a 2002 grand prix se with the 3100, so far I have added a new M.A.F, duel exhaust, fenderwell intake, and a timing mod I got off Ebay for 8 bucks, what other inexpensive mods could I add, and would a air ramp/vent mounted underneath the car to force air into my fender be worth the time. I'm kinda new at this so any advice would help
what else can I do??
2002 3100 = 3400 manifoldsBrian
3400 SFI V6, 4T60e
Re: what else can I do??
Originally posted by vsop4me3.1what other inexpensive mods could I add, and would a air ramp/vent mounted underneath the car to force air into my fender be worth the time.
Everyone here i'm sure has tried some sort of personal mod to their cars/engines, some more than others (way more)
Try your idea, take pics and let us know.
==95GTP
Originally posted by Canadian Badass v.2.0Originally posted by Rhedalert2002 3100 = 3400 manifoldsTaylor
1998 Lincoln Mark VIII
Get Fast Forward Performance's underdrive pulley...makes about 5 hp. $110.
Good thing you didn't spend anymore money on that timing advance thing....they don't really work. I'll bet it was a resistor that went into your IAT sensor.
Is your exhaust a FULL exhaust? Mandrel bent with a high flow cat and straight through muffler I hope.
I'd stay away from ported throttle bodies and your intake manifolds. They flow good enough for now, and are a bit involoved.
DO get either ASE chips or DHP's reflash....I've heard several different things about both....and they both seem like good options. Should set you back $300, but you get revised shift points and NO governor as well a slight bump in power.-1996 Beretta
3400 SFI / 4T60-E
-1991 Grand Prix SE
3.4L DOHC / HM-284
The 3100 PCMs use FLASH eeproms, therefore you can't replace the "chip". You have to find a company that will reflash the PCM. There are a couple companies out there, but the range of vehicles that they reprogram is VERY limited, so there is a good chance that you are SOL. And most basic reflashed run ~$300, with custom reflashed usually costing $500 or more.-Brad-
www.fastchip.com does reflashes and custom reflashes. I think the price is in the $300 range with it only being a little more for custom.
www.fastchip.com does reflashes and custom reflashes. I think the price is in the $300 range with it only being a little more for custom.-Brad-
