I want to do a complete rebuild from the ground up of the engine, and I want to make some considerable gains to the engine while I'm at it. I want to keep the original block, original intake, and it has to be normally aspirated. Everything else is up for change.
What I know:
-Increase compression ratio
-Increase air flow into engine through port and polish, K&N air filter, bigger throttle body
-Increase exhaust flow through cat back, headers
-Increase spark through Bosch Platinum +4 sparkplugs
-Increase fuel through increase in fuel injector rate
-Increase fuel pressure, penny trick anyone?
-Increase bore by increasing to 92mm from 90mm and using those pistons available from summit
-Decrease weight in rotating assembly, pulleys, and drivetrain
-Add cam
-Convert valvetrain to roller
-Decrease engine operating temperature with 160/180deg tstat
-Tuning ECM
Beyond that, I'm out of ideas, and do not know exactly what parts to get, like what cam would be good to provide more power but still keep mid range power that the 3.1L is so good at?
Will be tearing down the engine within a few weeks and will be sending it off to a machine shop to have the block and heads treated, and then the mass parts ordering will begin
Any help and ideas would be killer!! Thanks guys!
What I know:
-Add cam
-Tuning ECM
