Well, I am nearing the stage where I have enough money to keep working on my 3.4, and before sending it off to the machine shop, how do I know if it is a good idea to hone it or not?
From what I can tell, the engine was run pretty hard, and maintenance was not very consistent, which goes by what the driver told me; he ran the piss out of it.
The bearings have areas that look like they have had cavitation, and the cam bearings were worn down to the copper/brass, so it was abused, and it only had 140K
Which leads me to ask, how can you tell if it needs a hone?
The cylinders still have crossshatching visible half a quarter to a half-inch below the top of ring travel. The upper quarter inch of ring travel is polished smooth and the taper is big enough to feel with your finger. I have not measured taper but I have access to tools and can.
Suggestions? Ideas? What is an acceptable amount of taper?
