I have one of those ATV-Motorcyle Lifts...like the one Tom (WalterDude) used to lower his rear engine K-Member way back when...but the problem is that the hydraulic press and pump armature sick up at an odd angle and I would not be able to slip it under the car and not hit the fender well or something, I've been thinking about modifying a 20 ton cylinder to work with it after I use a cutting torch and get all that weird hardware removed,,,, It is just an idea I'm toying with right now.
Say...perhaps something like this would slip underneath the steel cradle and lift up the whole thing ....
