This has been irking me for a while now . . .
Complete rebuilt motor with a very mild build - motor runs great; still getting used to the chatter of having LS1 springs on the street
It's built tight (like I prefer) . . . but, first experience building a "performance" 60*.
Anyhow, after extended periods at idle, the motor starts to burn oil - not a problem when cold. I at first thought this was simply the rings seating and thought nothing of it, but after 500mi break-in, there's been no change. Alright, must be buggared valve seals (they were a little tighter than I expected installing, but they still installed fine) . . .
Through this time I've also been fighting a weird chuggle/hiccup that would occur only at idle, and seemed more frequent after longer idle periods as well. At first I passed it off to higher intake volume, and the PCM simply going through fuel trim re-learn. Didn't go away, and in fact got worse the longer the vehicle would sit. No codes, PCM data all appear perfectly fine . . . so, I figure perhaps the IAC is starting to fail (200K miles on OE sensor), and decided to remove the TB to clean the passages and all . . .
That's when I notice the pool of clean oil sitting right at the TB inlet - front of the TB is bone dry, only the back side. Only way it could get there is through the PCV (possibly the breather tube, but doubtful). I decide to experiment and through a vacuum cap on the PCV vacuum line and drove the car a bit . . . go figure, the smoking has practically gone away, and so has the idle hiccup. I put two and two together, and figure the motor is pulling a hard enough vaccum that oil is getting past the PCV into the intake, and coating the plugs . . .
So - my question (sorry it took so long to get to it
) - any ideas on how to curtail the oil flow into the vacuum lines while still keeping an operable PCV and breather? I had thought of installing a remote catch can, but realize that could affect the operation of the PCV (change in vacuum), and would still have to be drained occasionally (would prefer not to have to). I'm thinking my best option would be to pull the front valve cover off and make some kind of baffle under the PCV port - but not sure if clearance is a problem with the rocker (at least, right off the top of my head - if need be I can pull it and check the clearance).
I'm more or less curious if anyone has run into this already, and what kinds of ingenious work arounds were implimented (aside from disabling the PCV/breather entirelly - which is out of the question)?
