Where is your motor happiest? Mine seems to run best between 11.5 and 12, a little richer than other motors are typically run. It would seem they would run better leaner because of the chamber design.
WOT AFR?
WOT AFR?
3.4 block converted to roller valvetrain with 220/225 cam on 115 lsa, '769' heads with 3500 valves, LS6 springs & porting, twin T04E turbos, 3500 plenum with ported 3400 lower & 'short star' 65mm throttle.Tags: None
Yep. Mine already has some buildup, but that's from breaking it in. I'll have to suck some seafoam thorugh it.Increasingly I find the difference between a "fact" and an opinion is the number of people who believe it.
My 3500 was happiest with 26 degrees of advance and around a 12:1 AFR. Quite a few other engines that i've tuned like to be a little closer to 13:1 and 28 degrees (stock cam and SCR).
28* was what I ended up with.Increasingly I find the difference between a "fact" and an opinion is the number of people who believe it.
One way to find out. Ever take it to the track?Increasingly I find the difference between a "fact" and an opinion is the number of people who believe it.
Originally posted by robertisaar View PostLOL, the only vehicle capable of traveling there legally is wifey's LH0 GP.... i don't feel like pulling an 18 second timeslip
i imagine there would a few decent places to log a thorough 1st gear or 0-60 run without attracting attention though...
I tuned a cammed 3500 swapped 3rd gen Sunfire the other day, we just kept doing 3rd gear pulls up to 70 ish MPH on the highway.
