Hi guys, my Grand Am 3400 has just over 100K and it started losing power. Now the top speed is about 35 MPH. It sounds smooth at idle but acts like it's either starving for fuel, or drowning in it. I have changed the Air Filter, Spark Plugs, O2 Sensors, Fuel Filter, and that's what got me from 25 MPH to 35 MPH.
I have a bad back and really hate to work on transverse engines, but need to get it running. I do have some mechanical knowledge but it's limited on newer cars and I'm old, lol. I've tested the fuel pressure and it was good, though I can't remember the numbers right now. Any other suggestions or things that are common with this engine? The only other things I can come up with are:
Timing Chain
Various Sensors
Blown Head Gasket
Blown Intake Gasket
It doesn't smoke or steam out the exhaust and the last time I looked there was no water in the oil. It does however leak coolant somewhere and shows signs of it on the bottom Intake. If it needs very much I'm more likely to pull the engine and fix everything at once, outside the vehicle, but I don't have a great place to do so.
Any suggestions would help.
Axe
Timing Chain
Various Sensors
Blown Head Gasket
Blown Intake Gasket
Axe
