In an effort to possibly use my shorter than intended stroke crank, I'm trying to decide how significant an increase in quench height will be in the face of a resulting slight increase in compression.
I understand the dynamics, however this is a unique scenario. First this is a turbocharged engine which by nature will have turbulent inflow into the cylinder above what natural aspiration would produce.
Second, the quench height and stroke (3.31 to 3.48 ) would be increased and the piston volume decreased at the same time from 18 cc to 9 cc with a resultant slight increase in static compression of ~.1. The piston will go from .031 below the deck to .093 below the deck. The gasket thickness is ~.064 stock taking the OE .095 total quench to .157.
I can't find the info I need to make a decision. I'll have considerably increased quench which usually is a bad thing however, the uniqueness of fast burn heads, higher resulting compression despite the increased quench and the turbulent airflow due to turbocharging to counter the lost mixing effect normally caused by optimum quench.
I've read some say it doesn't matter as much on a turbocharged engine. My personal experience with contrary to popular belief theory is with putting iron heads over aluminum head pistons in a 3100 resulting in considerably lower compression turbocharged. Despite the suggested 7ish compression ratio, in my Fiero with the 4-speed manual turning about 2800 rpm on the interstate, it still pushed the car to just shy of 28 mpg with new tires and a tune up, about the same as the original 2.8L with 8.8:1 compression and no turbo. Doesn't make a lot of sense to me.
That's a 3100 block and pistons with the Fiero 2.8 intake and heads.
So, will the increased quench have a drastic effect eventhough the compression ratio increases at the same time?
