I seen those. I'm not sure why anyone would use them ,they look like box cars sitting on top. they must have some good weight to them.
lx9 roller tip roller rockers anyone?
Originally posted by grnrdragon View PostI seen those. I'm not sure why anyone would use them ,they look like box cars sitting on top. they must have some good weight to them.As far as weight, they are gonna weigh the same as any other aluminum body rocker.
Originally posted by SappySE107 View PostStiffer is far more important than weight for most applications.
bszopi I realize no one but you would see them, wasn't try'n to disrespect you or your stuff ether.
Originally posted by grnrdragon View PostSo why aren't there more people using stainless, nickel, or even titanium rockers?
What we would need is someone to design a narrow body chromoly rocker specifically for our engine, ideally a self aligning and self adjusting one like stock, with a roller tip and fulcrum and ideally also in different ratios like 1.7 and 1.8:1. If someone made those I'd buy a set myself to get rid of my AL floating rockers. People have been trying to get some made for years though and I don't see it happening.
Honestly, there is very little to gain if anything from going to a roller tip floating rocker in the stock ratio versus the stock rocker. You have to get guide plates and different pushrods, and set the lifter pre-load every time you take them off, they are noisy, and whatever you gain from the roller tip you probably lose in lateral motion and drag from the guide plates and heavier pushrods. I'd just stick with the stock rockers and use good oil for lubrication. At the rpm we typically are turning it won't make much difference. IMO if you could run higher rpm like 8,000 or so then it might make more difference, but there are other limiting factors preventing us from doing that (like a weak timing chain, and transmission constraints), so it's a waste of time anyway.'97 Grand Prix GT 3800 (sold)
Gotta love boost!
