3x00 SC setup, from the factory
  • 3x00 SC setup, from the factory
    I should just post the pics, but I'm lazy.
    You'll never see it, but its a pretty sweet, one-off setup... and its for sale.
    Nice setup. Makes me want to rethink the mounting and plumbing on my setup.
    Marty
    '99 Z-28 - Weekend Driver
    '84 X-11 - Time and Money Pit
    Quote of the week:
    Originally posted by Aaron
      its for sale?
        Yeah...only $4500. Its a steal!
        Marty
        Quote of the week:
          You can build that easy if you think about it. not hard at all.
          1984 Indy Fiero 3.4L
          13.7 sec @ 98 mph
          *ALL THROTTLE AND NO BOTTLE*
            Take a quick look at the manifold. Its a 1-piece, sand cast manifold. Not really that easy to fabricate. Something similar, perhaps... if you can TIG weld.
              man i wish i had 4500$
                If you look at the third pic, it looks like they took a stock manifold and cut the TB neck off, welded some flat aluminum to fill the hole, and ground it smooth. Defintely a job for a TIG welder.
                If I had another 10" of hood clearance, this would work
                Marty
                Quote of the week:
                  Hmm... Wonder if it would fit the Impala bay?
                  \'03 Impala with 3400
                    There are a couple of setups like the above out there besides this one, I used to have pictures of around 5 or 6 cars w/ this identical setup, I lost them when my harddrive crashed about 1.5 months ago..I'm sure others have posted about this particular setup here before????
                    Matt F.
                    TGP 1/4 mile times
                    http://photobucket.com/albums/y33/mfewtrail/
                    1990 TGP Coupe VIN Database
                      None are identical to this, since all the others are not intercooled. This is a truly unique piece, but will require quite a bit of effort (and $$$) to make it work.
                      Matt
                        I was saying that some setups were identical to the picture I posted, not the setup posted about here originally. I should have made that clear in my initial post.
                        Matt F.
                        TGP 1/4 mile times
                          Actually it will fit in an impala bay it may require a custom hood, but I'll check clearances for you if you'd like
                          Chris White
                            Please do.
                              Ok my 60 degree equipped W-Body is nowhere to be found right this second I'll have to get back to you
                              Chris White
