3.1 crankshaft casting numbers?
  • 3.1 crankshaft casting numbers?
    Whats the difference between the crankshafts for the 3.1 that have 981 and 268 casting numbers??
    1996 Beretta
    3100 SFI TURBO
    13.1 @ 103 mph best in the 1/4 mile
    981 has the 7x ring for MPFI, 268 is the RWD crank that doesn't have it.
      so can i use a 268 crank in my engine its a 3100 fwd??
      1996 Beretta
      3100 SFI TURBO
        How are you going to trigger the ICM then?
          ICM? idk thats why i ask i ordered a crank with casting 981 and it was junk so they sent me this one....
          1996 Beretta
          3100 SFI TURBO
            The notches in the crank are for the crank position sensor. This sends a signal to the ICM (ignition control module) which then tells the ECM the position of the crank so that it fires the spark plugs at the right time. If you got a crank without the 7x ring, then your car basically isn't going to start.
              wtf now i gotta try and get these people on ebay to send me another crank ugh. thanks for the help
              1996 Beretta
              3100 SFI TURBO
                wait check this out 981 crank for a rwd no notchs my 268 has em
                http://cgi.ebay.com/ebaymotors/90-91...item51910aead8
                and this....
                http://cgi.ebay.com/ebaymotors/GM-3-...item51892c98a3
                1996 Beretta
                3100 SFI TURBO
                  If your 268 has the notches then it should work. Go figure GM would do something stupid like have the same casting on 2 different cranks... lol
                    ALL Cranks cast after 87 were internal balance and had the timing disc cast into the crank. Weather it was machined with notches or not depends on the application.
                      wow thats messed up yeah i compaired the cranks ive got 3. 2 981s and a 268 they r all the same. they all have 7 notchs and they r all in the same place on all the cranks so im gunna use it i guess...
                      1996 Beretta
                      3100 SFI TURBO
                        I always thought a casting number was used to keep track of a certain cast and when the part started to show flaws they would scrap that casting number mold since it is wearing out.
                        but as you have seen as long as it has the 7 notches you should be good to go.
                          They could just be cast in different plants.
