torque converter
  • #31
    my PCV valve is oem so that shouldn't be the problem. would a vacuum leak cause this? i think i might have a bad LIM seal but im not sure. im also going to do a compression check to double check my valves and head gasket. cuz i didnt lap the valves or anything when i put them in the head. something just feels off..but i didnt care much cuz the car is getting ripped apart soon enough anyway to put the ported heads on.
    but under acceleration it makes like a vvvssshhhhhh...i know..very helpful, right? ill try to get a video sometime. i always thought it was just the new tighter belt that made the noise. cuz its all engine at idle then u can hear that noise when gas is applied. idk
    but ill try to figure out my idle-gear situation. kinda pissed to find out it doesnt really have much to do with the converter..so another issue.
    • #32
      How long ago was the PCV valve replaced? Does it still rattle? If you think it's a vacuum leak (which it could be since it's got a noise under accel), try spraying gasket mating areas and rubber hoses down with some carb cleaner. If your idle changes you just hit a vacuum leak. Propane also works in place of carb cleaner.
      • #33
        Actually, your description of the sound is helpful. If I am correct, it sounds like you have an obstructed exhaust.
        • #34
          alright ill do the carb cleaner thing to test stuff out. and its also possible it is an exhaust leak because i was very gentle putting the manifolds back on cuz i didnt want to break another stud..so it might be lose?.. ill try things out..ill poke around and see if the noise changes.
          ill try to get a video up of my car driving and idling...there are a few issues id like to address and i think it'd be easier for u guys to help me if u could see/hear it.
          • #35
            You don't have to be gentle with manifolds. Torque them down to spec. A stud shouldn't break unless there was something wrong with it or the nut when applying the correct torque.
