[quote="Aaron"]Well the guy is in high detail, and to some of us that is a good thing.....[quote]
So, does this confirm any questions anyone had about Aaron??? Just joking!
I don't mind the intake so much. I hope they start putting them in some cars fairly quickly so that they start showing up in junkyards and ebay! :P
Now the real question is how do you phase a single cam motor? Usually you change overlap as one way to increase higher rpm HP. I guess they could have some funky cam over cam setup so you rotate the outer shaft and inner shaft separately.
Usually they just use a servo to move the cam independantly of the gear.. either advancing or retarding cam timing.
What I want to know is, can you swap the dualstage intake (upper/lower) on an older motor, or do the heads come with? Either way.. I can see another hybrid swap coming on.
But unless somehow the intake and exhaust lobes are separated and can be moved independently, you can only advance/retard the cam timing for the whole cam.
