I must have picked up a wild hair somewhere, because I'm seriously considering dusting the iron heads I've been working over and going with 3100/3400 heads on the 3.1.
The 3.1 short block is already assembled with the iron head pistons (12cc dish), so I'd be looking at nearly 11:1 CR. Seems too high for the intended purpose, especially since this will be boosted.
If gen 3 heads can be opened up to about 35cc's then the CR Calculator tells me that the CR drops to 10:1. Might be able to go with 8 lbs boost with proper intercooling and tuning.
Is there enough metal in the head to remove 6.5 cc's from the combustion chamber? Seems like a lot to remove.
The quench looks crappy with the iron head pistons and gen 3 heads. How important is quench in a boosted application? I always thought there would be sufficient combustion chamber turbulence just from boosting, but would a quench distance of .077 cause other issues?
I've got a spare set of rods, so I suppose I could just get a set of gen 3 pistons and move on, but what's the fun in that?
