i will be installing fiero valve covers on my 3.4L engine. i know that i need to change that studs to a larger diameter, but which ones and where to get them? i have the fiero bolts with spacers, but i prefer the studs so i can mount the spark plug wire holders. your thoughts please.
fiero valve cover studs
Yea use the studs. You do not need larger ones. If you have an S-10 or Camaro keep all the short studs. Any long studs with the extension to hole the plug wire clip wont work. Replace those with the short ones. Find nuts with a large built in waster to retain the covers.
