Alright guys, I'm not getting much help/info/testimonials over on TGO, so has anyone successfully run 12.89 CR or higher on a gen 1 or 2 block? Or can at least tell me if they think it is viable or not? And what potential issues there will be other than detonation, or I'm also thinking about running E85 for 100+ octane, anyone converted to run it that knows what I would need to do?
12.89:1 CR...doable? E85 maybe?
assuming the bearings can handle it. i know a guy on here that had 12.5 CR with the stock oil pump. ruined the rod bearings over time.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
The stock oil pump has nothing to do with the bearings lasting. The problems was more likely due to detonation1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
one of the domesticcrew guys had a hybrid with like 12:1 scr and a Crane H272 cam. I seem to remember him running it on regular pump gas.
like betterthanyou said though, it depends on the cam.
I'm getting a solid flat tappet from crower with a 3-7k powerband and 8k+ redline. 248* int and 250* exh @ .050 lift, and .501 gross lift on intake, with .511 exhaust.
If someone could explain the below thing or tell me what # it is from those above that would help in that i could find the dynamic CR.
"Intake Closing Point (degrees)ABDC @ 0.050 lift plus 15 degrees"Last edited by 2.8/3400 1985 Camaro; 03-09-2010, 07:19 PM.
you won't be able to drive that on the street.. that cam has 79 degrees of overlap. It will have to idle at 1300 RPM.
Well, with a huge ass stall, or 5spd it might be drivable with that idle.. LOL... manual you could just slowly let out the clutch without touching the pedal probably.... hahaa
IVC ABDC spec you need to get from crower..
With that much overlap, it should bleed off a ton of compression I would think.sigpicNew 2010 project (click image)
Over lap does not tell the whole story. Pressure bleed off depends mostly on the IC event. The later is closes the more pressure will bleed off. You do not necessarily have to have a lot of overlap or duration to bleed off cylinder pressure.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
IVC (ABDC) would be 48.0 @ .050
no, i didn't add the 15.
That's a race only cam. Probably circle track, sandrail or for a '660 powered boat. Under normal driving it's going to need a pretty high stall converter, your brakes and other vacuum driven accessories will barely work and probably non-stop tuning. Since it's a mechanical cam it's also going to be noisy and you'll have to adjust the rockers a few times a year.
I run a pretty extreme cam in my 3500, trust me.. if you enjoy driving the car go with something a little more tame.
I think something like the Lazer cams 2700122 would be a better choice..
3rd up from the bottom: http://members.shaw.ca/betterthanyou...haft_guide.htm
It depends on what heads you are using as well, that much cam on gen1 or gen2 heads is a waste of time.
