I have a set of APR Rod Bolts and went to have them pressed in and the shop said that the holes have to be enlarged in order to fit them. Is this true?
ARP Rod Bolts
ARP Rod Bolts
1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut BracesTags: None
Whats the best way to get these in? What kind of press?1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
Like this one?
Cool. So I have a couple more questions
- Will that press work?
- Do I have to get them honed? Ive read that it messes the bore up.
- Basically how do I install them? lol
Originally posted by pocket-rocket View Postsigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
So when I drop them off, I should say I want the bolts installed and have the rods resized and cut? And what does it mean to cut them?1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
having the rods resized means to bring them back to within the OEM specs and as for having them cut....i don't really know the answer to that, maybe it means cutting them where the parts meet (the rod and the cap)? I've never heard the term "cut" in the machine shop?. Maybe someone can explain.
EXAMPLE:
A ( )----- B
In this illustration part A is the cap and part B is the connecting rod, and in the middle space, for illustration only, is where the two meet and the bolt holds the two together, maybe the part where they meet has to be "cut" because it may be warped and just needs to be true again (Straight, Flat)
Maybe I'm wrong but that's my 2 cents. Late.I need a bigger engine!
Thanks for all the info guys! They are at the shop as we speak!1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
