Wide Band!!!!!!!!!!
Wide Band!!!!!!!!!!
As of April 2
Engine: 2006 SV6 3500 LX9
Trans: 2002 Getrag F23 5speed
Injectors: #36 GTPs
TB: 65mm TCE
Maf: 1999 3400 Montana.
Beverages: Ice Cold CANADIAN.Tags: None
I know the Innovative LC1 is a very popular unit, and there are several people on here that currently own one. As far as unplugging the controller, I have no idea.-Brad-
As long as you have two of the same o2 sensors then yes the controller can be used on multiple cars. Typically these are just Bosch LSU 4.2 type wideband O2 sensor regardless of the controller included.
One thing to remember is with this kit I think you need to calibrate it every time you switch the sensor thats connected to it.
My PLX wideband I do not need to calibrate ever.Last edited by 3400-95-Modified; 02-24-2010, 02:47 PM.
The manual recommends re-calibrating (heater warm-up time and free-air) the controller everytime it's connected to a different sensor. Since you have to remove the O2 sensor from the exhaust for free-air anyways, you might as well just save time and use 1 sensor for both cars and plug the bung where it's isn't being used.1995 Grand Am SE
Thinking that since they need to be recalibrated when moving from car to car, I will just worry about my car, this kit or similar, then get the PLX after to go from vehicle to vehicle.As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
Originally posted by ForcedFirebird View PostYou don't have to remove the sensor to do free air calibration, just make sure the car hasn't been started for at least 6hrs.
I had the LC1 (might still have it actually) and wasn't happy with the performance of the controller, so I made my own...
Firmware can be buggy when it first comes out though.
