here is his actual sight..... http://www.marcellamanifolds.net/
Custom Intake Manifold
Originally posted by RedZMonte View Postthe suspention can be lowered by adjusting the bolts on the mono leaf in the front. lol the "Corvette Lowering Kit" is literally 4 grade 8 hardend bolts.. so easy to do.
S
Originally posted by kwhauck View Posthere is his actual sight..... http://www.marcellamanifolds.net/-60v6's 2nd Jon M.
Originally posted by 02dohc View Postyes it is a stereo lithography setup.
now i miss my machine shop ...
I have thought about modeling it in CAD (as that's what I do all day long as well), but I think I have decided to just build a mock-up out of wood/foam and see what I come up with. Once I get it mocked up, I will then transfer the pieces to CAD, which can then be sent to a laser/water jet to get cut out and then welded up.-Brad-
i was thinking about a hybrid between the 3500/3400 UIMssigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
who was building a vortec style manifold out of mandral bend steel?
a m90 might be a little big but wat if u put the s/c upside down because they can be put in any direction (refering to pic above) under the steel runners with a box above it with all the runners going to it. so the injectors could stay put but it would be a little tall. i dont know much about boost but puttin in my 2 cents.
An M62 probably wouldn't fit in that space, let alone an M90. Besides, even with the setup above, it was ~1" too tall to be able to close the hood of a W-body.-Brad-
i think i gotta be the first one to make a LIM to replace both upper and lower's. might take 2 years though till i finish the T/A and the truck.
i found this on j-body.org. its a third gen cavalier. not sure how the adapter was made but is pretty low profile.
Don't think I would call sticking out of the hood 3-4" low profile...-Brad-
