My TGP (Gen II 3.1) bottom end needs new lifters as a couple are completely collapsed, but I've seen nothing but cheap Chinese junk for replacements from the parts stores and such. I've searched on here, and haven't found anything conclusive.
Does anyone know of a good set of replacement lifters?
Also, are Gen II lifters the same as Gen I lifters? I'd think that the flat tappet setups are the same, but I'm not sure. If they are, then I can look into mild cam upgrades as well, as several (all?) flat tappet cams come with new lifters anyway. Might those include 'good' lifters?
One last Q... I've never replaced flat tappet lifters without replacing the cam also, is it even okay to do that? (new lifters on old cam)
I thought I was done with this flat tappet junk but this engine was in the right place at the right time. My 'real' build will have a roller cam (Gen III), but it's easiest and cheapest to use what I have now, for now.
If you have valid info, please share. Thanks!
