Originally posted by Schmieder
View Post
That would be the correct way to set pre-load on hydraulic roller lifters if you are using adjustable (floating) rockers. Those go over a stud in the head and have a nut that holds them on. The stock rockers sit on a solid metal pedestal that keeps them aligned so you don't need guideplates and automatically sets the preload because they are all at a pre-determined height. You just tighten down the bolt in them and torque them. Not sure when they started using those rockers though. You must have the earlier version that still used guide plates I assume?
