Ok guys, I've looked all around and I can't find a solid answer.
What is the safest torque/hp maximum for the 4t60e auto transmission?
Considering the tranny was rebuilt 2-3 yrs ago and is in great shape, well taken care of. I also am employing a B&M Super Cooler rated at 14.4K BTU after the trans fluid passes through the radiator. Using a TRANS TEMP gauge rigged to read temps before the fluid hits any cooling unit.
Actually, two questions...
Safest torque/hp maximum?
Maximum safe temp levels?
I'm using a program called Dyno 2003. It seems precise as I entered all the general stats for my car in great detail. Camshaft, stock heads flow charts, tire radius, frontal area, ect. I got the hp/torque results in the same region as factory specs.
Now I can also input the turbo info to get an idea of hp/torque figures. Trying to hit a good strong number at the safest max the engine can handle. And I mean safest as in no catastrophic failures, increased wear and tear is expected. The block will be rebuilt or replaced in a year or two. (reinforcing internals so I can start boosting up near 20-25 psi)
Thanks for the help!
