What would it require to effectively swap an in-tank pump for an in-line pump outside of the fuel tank?
Is it as simple as running a sealed fuel line with filter where the old pump use to be and generally hooking up the inline unit?
Or is there more to this?
Can an inline fuel pump be installed after the intank pump and use both pumps. Just wiring both pumps from the same wires.
I think, key word there, that it would make both fuel pumps less stress to operate. Or would the inline pump, which will be stronger, cause problems for the intank pump?
Can I unplug the intank fuel pump and leave it there while running an inline pump? Or will the dissabled intank pump not flow at all when shut down?
Thing is, I need to up grade my fuel pump to something stronger. I had the Walbro 255 in mind but can't find one that is designed for the 1996 Grand Prix SE. There are ones for the 1997+. WIll those work just the same or is there design differences in the pump, housing, ect?
I tried searching these answers to no avail.
You guys have been a tremendous help. I couldn't do this turbo project with out this site and the wisdom there-in.
2010!!!
2010!!!
