Need a Big Bump Stick!
  • Need a Big Bump Stick!
    Buliding a 3.4 iron head and need a new bump stick for the build..
    looking for a grind: 1.5:1 rocker
    Valve lift: .489, Ad Dur: 277*, cam lift: .326" dur@.050: 230*, lobe cen: 110*
    and come in just under $150...
    thanks
    sigpicWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
    You plan on getting lifters with it for that price? Not going to happen on a custom cam, maybe something of the shelf.
    EDIT: Actually that's not a crazy bump stick and I have one very similar I installed in an engine never ran. Would sell it for $150 plus shipping (including lifters). Also hve a 252 and 260h I need to get rid of(they are nitrided though, more $$).
      you should check with ari motors . they have alot of cam choices for the 2.8/3.1/3.4 at deacent prices
        you can get the same cams they offer for lower prices from Summit and other online vendors.
          We can offer more of a variety for similar prices. They still have the Crane listed for $300
          Little longer .006" duration that you are asking for, but here's the cam card for that "used" cam I have (was going to be N/A and changed my mind mid-build)...
            60V6 has never and will never recommend ARI.
              With 1.6:1 rockers thats a IN:.484 and EX:.496
              That's really close and I think I may just take that off your hands! Will it have a Lopey idle?
              --The cam I mentioned above is an Engle Cam. Part# 21646-H Grind# EP-46HYD
              Discription: Hot Street, with lopey idle 9-10 to 1 compression. Hot street & strip power, 2000-6000rpm
              ya... So what's with the bad blood with ARI on this site? Who they screw over?
              I've never delt with them.. just curious????
                Cheap-Fast-Reliable
                Pick any two!
                  It better be lopy with that tight of of an LSA.
                    ForcedFireBird: PM sent!
